Thalador
Oct 24, 2020Apprentice
Cannot login to admin page
Hey folks, I have an RBK753 system which has an RBR750 and two RBS750 sattelites. Since I upgraded to the latest firmware 3.2.16.6 I can rarely get into the administrative page either via the IOS...
Mstrbig
Oct 24, 2020Master
This is not normal. I have the same system and updated my system to the latest firmware as well.
I assume you followed the instructions and updated the satellites first, then the router?
I suggest a factory reset and reinstall. You can backup your settings before you reset to save setting it back up again.
- ThaladorOct 24, 2020Apprentice
I did follow the instructions. I am thinking a reset is in order but I cannot get to the page to back up the config. Another very odd thing, I have 1Gig internet and from my desktop when I run a speedtest.net I usually get about 900/900. Right now I am getting 90/90. Something is very wrong here
- MstrbigOct 24, 2020Master
Thalador wrote:I did follow the instructions. I am thinking a reset is in order but I cannot get to the page to back up the config. Another very odd thing, I have 1Gig internet and from my desktop when I run a speedtest.net I usually get about 900/900. Right now I am getting 90/90. Something is very wrong here
Is your orbi router in AP mode or router mode? If in router mode, unplug it from the ISP modem and see if you can access it via orbilogin.com, 192.168.1.1 or 10.0.0.1? Try doing this with a cable plugged in from your desktop or laptop?
So I just did a factory reset and everything is working except my desktop is still capping at 99/99 instead of 900/900
