Thalador
Oct 24, 2020Apprentice
Cannot login to admin page
Hey folks, I have an RBK753 system which has an RBR750 and two RBS750 sattelites. Since I upgraded to the latest firmware 3.2.16.6 I can rarely get into the administrative page either via the IOS...
Thalador
I did follow the instructions. I am thinking a reset is in order but I cannot get to the page to back up the config. Another very odd thing, I have 1Gig internet and from my desktop when I run a speedtest.net I usually get about 900/900. Right now I am getting 90/90. Something is very wrong here
Mstrbig
Oct 24, 2020Master
Thalador wrote:I did follow the instructions. I am thinking a reset is in order but I cannot get to the page to back up the config. Another very odd thing, I have 1Gig internet and from my desktop when I run a speedtest.net I usually get about 900/900. Right now I am getting 90/90. Something is very wrong here
Is your orbi router in AP mode or router mode? If in router mode, unplug it from the ISP modem and see if you can access it via orbilogin.com, 192.168.1.1 or 10.0.0.1? Try doing this with a cable plugged in from your desktop or laptop?
- ThaladorOct 25, 2020Apprentice
So I just did a factory reset and everything is working except my desktop is still capping at 99/99 instead of 900/900
- Mikey94025Oct 25, 2020Hero
Thalador wrote:So I just did a factory reset and everything is working except my desktop is still capping at 99/99 instead of 900/900
Glad you have access to your admin page again. Follow the steps in our community FAQ to diagnose your speed loss: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1984305/highlight/true#M7944. In particular, check your desktop's network cable type: Verify that you have at least Cat5E or Cat6 cabling or try different cables, otherwise other cable types or bad cables may throttle your speeds to 100 Mbps
