spewak
Oct 14, 2021Luminary
Cannot login to router
I just purchased an RBR850 that I cannot get setup. The problem lay in trying to setup the admin password for the router. Press next and no access. There is a constant white light emanating from the ...
Oct 14, 2021Guru - Experienced User
Press the reset button for 15 seconds then release, with the RBR disconnected from the ISP modem/ONT, connect one wired PC to the back of the RBR? The front LED should blink WHITE then pulsate WHITE, after it pulsates WHITE, try to log into the RBRs web page at 192.168.1.1
spewak
Oct 15, 2021Luminary
Thanks Furry.
I have had Orbi's on my network for years but the setup out of the box on this one had me in knots. I finally was able to proceed past the Admin account settings. Woof. I was able to get it and the sat. setup. Thanks again for your response.
- FURRYe38Oct 15, 2021Guru - Experienced User
Good to hear.
Please mark your thread as solved so others will know.
Enjoy.- spewakOct 15, 2021Luminary
Cannot mark as solved...apologies. It famously took a nap on me and then I tried to downgrade the firmware. I was successful in doing that but then the bugger upgraded to the newest firmware automatically. I removed it from my network and reinstalled my RBR50 until such time as they issue a fix in a future firmware update.
- FURRYe38Oct 16, 2021Guru - Experienced User
And is there a problem after the Orbi AX system updated to v16?
