AGore
May 19, 2022Guide
Cannot login to UI RBR850
have lost connectivity to RBR850, don't want to do a factory reset please help.
May 19, 2022Guru - Experienced User
Factory reset seems to be the fix but if you don't want to do so, you can follow the "wait and see" that some are using.
Supposedly a fix is in the works being tested but nothing released to everyone.
You can check the status page here:
https://status.netgear.com/?_ga=2.4349171.1931687571.1652963238-1778895679.1650539008
