bmentink
May 01, 2024Guide
Cannot login to webpage as Admin any more
Hi, I have a new Orbi mesh router that is all setup and working. I had to setup up some NAT stuff, so went into the devices web page on my computer, and also changed the admin password to so...
- May 01, 2024
Ok, I fixed this with a reboot of the Orbi ..
So it seems, it is a firmware bug, to my mind it should not perform like that, I would not like my customers to have to go though that in one of my net connected products.
May 01, 2024Guru - Experienced User
What model Orbi system do you have?
What browser are you using? This happens in other browsers like MS Edge or Firefox or Opera?
Be sure to clear out all browser caches and saved PW profiles with in the browser.
bmentink
May 01, 2024Guide
Orbi Wifi 6 AX1800 RBR350
EDIT: found out via android app v4.20.0.4
? No idea .. provided by Chorus New Zealand
Brave
No difference
