bzkfrl
Dec 21, 2024Aspirant
Cannot Pair RBS750 Satellites to RBR750P Router
I've been using the RBR750 with two RBS750 (FW 7.2.6.31) satellites with excellent reliability and ease of use for 5 years. Several days ago, after a lightening strike near the house, my router fai...
- Dec 21, 2024
I see now that the compatibility chart clearly shows that the RBS750 is NOT compatible with the RBR750P. When purchasing the replacement system, Apparently, I need to purchase a RBS760 satellite to be compatible with the RBR750P router. I made the mistake of assuming that the 750 series model numbers would be compatible. I wish I would have looked at that chart sometime during the first hour of my time with the tech support (would have saved us 5+ hours on the phone). Thanks to each of you for your help and Merry Christmas!
CrimpOn
Dec 21, 2024Guru - Experienced User
Could you please look at the product label on one of the new satellite and verify the product number?
(i.e. is it RBS750P or RBS760P)
My guess is that you're screwed. Not surprised that Netgear support could not come up with a solution. The "official" list of Orbi compatible satellites does not list the RBS750P satellite at all:
https://kb.netgear.com/000065169/Which-Orbi-routers-and-satellites-are-compatible
(Notice that it says the RBR750P is compatible with only one AX satellite, the RBS760. Either Netgear failed to include the RBS750P or the satellite is named RBS760P)
Firmware for the 750 product line jumped from version 4.x to version 7.x (with no 5 or 6 in between) in summer of 2023 when the IoT feature was introduced.
The 750P product has had only one firmware release (the first, dated 2/9/2024)
Satellite compatibility has been a puzzle with the AX products. Whereas the original Orbi WiFi5 systems allowed all of the satellites (RBS50, RBS40, RBS20, RBS10, RBS30W) to connect to any of the routers (RBR50, RBR40, RBR20, RBR10), the AX products seem to function differently. The few instances of "inter-connection" have led to customers experiencing strange problems (such as the RBR750 router with RBS350 satellites which fail if the router firmware is upgraded).
I have this terrible premonition that your choices are:
- Purchase additional RBS760P satellites if you require more coverage (certainly not cheap), or
- Return the purchase to Best Buy and get a different package (or a different system entirely)
bzkfrl
Thanks for your quick response. I've confirmed that the product label is RBS750P. Regrettably, I've discarded the packaging for my 750P purchase and Best Buy will not accept the return. I just didn't anticipate this kind of compatibility problem with this family of products.
- FURRYe38Dec 21, 2024Guru - Experienced User
Seems that the 750P series is from a 350 series hardware, thus this sepecific version of RBS and FW is not compatible. You'll need to downgrade the RBR750 back to prior working version of FW for the P series kit, RBR and RBS.
- bzkfrlDec 21, 2024Aspirant
Could you expand on which devices you are suggesting that I re-flash? The RBR750 is dead. I have two RBS750's. Which firmware version should I upload to them?
- CrimpOnDec 21, 2024Guru - Experienced User
It is really frustrating that people who volunteer on the Community Forum do not have access to information which might help in situations such as this one. For example:
- Some products have a "letter after the number", such as 750P. What does that 'P' mean? Nobody can find any documentation explaining it.
- There is no access to the source code. If the source code, for example, contained instructions to examine communication from the satellite for specific information (like, "if the satellite does not say 'RBS750', don't talk to it") that would explain what is going on.
- No one (as yet) has been able to capture the actual communication between router and satellite. The WiFi backhaul channel is encrypted (like all WiFi), so capturing the traffic is not trivial as it is with Ethernet. Even if the communication could be captured, perhaps even the 'wired' connection is also encrypted.
I have a strong feeling that Netgear has a very strict definition of 'compatible'. For example, the WiFi6E and WiFi7 systems support the 6G frequency band. A satellite which does not support 6G WiFi thus cannot possibly be 'compatible' with such a router. (even though it may offer all the same features, such as IoT).
The RBS750 and RBS750P satellites have different hardware:
- RBS750 has six amplifiers and antennas: RBS750P has only four.
- RBS750 has quad core 1.4G processor: RBS750P has dual core 1G processor
- RBS750 has a WiFi chip supporting 1024 QAM for all channels. RBS750P supports only 256QAM on the 2.4G channel
- The amount of RAM and flash memory are different
Thus, they are different. How could anybody think they could be 'compatible'? Answer: a customer who sees "Orbi" and "750" in both product names might think they should work together.
Unfortunately if the RBR750 died and the newer RBR750P which is NOT a actual RBR750, and you have RBS750 actuals, you'll not be able to connect these to the P series system as these are not compatible with this P series system.
You'll need to either get another RBR750 actual model router or give up on the actual RBS750s and go with the P series system.
