sltoffler
Aug 05, 2020Aspirant
Cannot pause or block internet for network connected devices
I am using the Orbi RBR850. Firmware: V3.2.15.25_1.3.15 I cannot pause or block any network connected devices either from the app on my iPhone or through my browser connecting directly to the ne...
- Aug 05, 2020
It worked!!! Thank you so much!!!
By simply applying that FW upgrade, it now supports the pausing/blocking of internet to connected devices on the network.
The only other question I have...I was able to upgrade firmware on the router but not the satellite. Is that normal or should I try something else to upgrade that one?
Aug 05, 2020Guru - Experienced User
Try using v32 FW and see.
Do you have IP address reservations for the devices your trying to block? Try this as well.
- sltofflerAug 05, 2020Aspirant
how do I get v32 FW? When i check firmware status, mine says it is completely up-to-date and no FW available.
- FURRYe38Aug 05, 2020Guru - Experienced User
Be sure to try to set IP address reservations for your devices. then try to block them.
Thanks for the link to the FW update. Not sure why when check for updates through the app it says there are none available.
I'm a novice here...can you explain what you mean by setting IP reservations? what exactly is that and how do you do that?
