sltoffler
Aug 05, 2020Aspirant
Cannot pause or block internet for network connected devices
I am using the Orbi RBR850. Firmware: V3.2.15.25_1.3.15 I cannot pause or block any network connected devices either from the app on my iPhone or through my browser connecting directly to the ne...
- Aug 05, 2020
It worked!!! Thank you so much!!!
By simply applying that FW upgrade, it now supports the pausing/blocking of internet to connected devices on the network.
The only other question I have...I was able to upgrade firmware on the router but not the satellite. Is that normal or should I try something else to upgrade that one?
Aug 05, 2020Guru - Experienced User
Be sure to try to set IP address reservations for your devices. then try to block them.
sltoffler
- sltofflerAug 05, 2020Aspirant
I just found the FW upgrade for the satellite and upgraded it successfully, too!
Again...can't thank you enough for your help!!! All is working now!
