diz420
Jun 12, 2024Aspirant
Cannot unblock site using admin tool
Hi, I blocked some sites using the security/block sites feature in the admin tool however the sites remain blocked after I removed them from the keyword list. I was able to do this in the past. I ...
diz420
It never posted such a screen. It essentially tries to connect and receives a browser connection timeout error.
CrimpOn
Jun 12, 2024Guru - Experienced User
Can you compare several web browsers?
- CrimpOnJun 12, 2024Guru - Experienced User
This is Part 1 of a two part post:
I just did an experiment with Windows 11 Pro. Set up "ford" as a keyword to block and set to block "Always".
Opened Edge browser and entered:
Notice the "http" which forces the browser to look for an unencrypted connection:
The result is this:
Opened a new tab and entered this:
Notice the "https". This time, the Ford.com web site opened as expected.
So, let's try Opera:
The result is this:
now try encrypted:
Ford.com web site opens.
Let's try Chrome:
Oh, my. Chrome appears to switch to "https" when "http" fails to produce a connection. Helpful, but renders my site blocking attempt totally useless.
Firefox?
Oh, dear. Firefox also opens the encrypted web site.
This is the reason I concluded that Block Sites is essentially useful as a means of controlling what users can and cannot access. (There are other reasons as well.)
Part 2.
As another experiment, I entered a keyword for a web site that does not exist, sexykitten.
What happens with these four web browsers when I attempt to connect to the http (unencrypted) version of this non-existent web site?
Edge:
Opera:
Chrome:
Firefox:
Notice that all four web browsers returned a DNS lookup error. None of them remarked that the Orbi Firewall had clocked connection to this URL.
My conclusion is that the Orbi Block Sites mechanism only reports that the Firewall has blocked access to the web connection when the DNS lookup is successful. Personally, if I had been programming this, my choice would be to deny the DNS lookup up front and never attempt to make a connection at all.
(for me) this moves the investigation from Orbi Block Sites to "How do we establish that this web address is real?"
- diz420Jun 13, 2024Aspirant
Same result across browsers and devices. Are you with Netgear tech support?
- CrimpOnJun 13, 2024Guru - Experienced User
Alas, Netgear support staff and software engineers do not participate in the Community Forum. I retired some time ago, have no interest in golf, and came to the forum because I had a question, my 90 days of 'complimentary support' were long past, and a kind person on the forum solved my problem.
The point of those rambling posts was that when the Block Sites mechanism on my RBR50 Orbi takes action, the result is a message that the Orbi Firewall has blocked access.
This morning, I did the experiment again using an RBR750 with most recent firmware, and found that the "Firewall" message does not appear on Chrome, Edge, Firefox, or Opera. This leaves web browsers thinking that the URL did not match any entry in the DNS process rather than that the Orbi Firewall had blocked access. (Personally, I find this behavior less useful than the previous behavior.) It is frustrating when different versions of the Orbi firmware behave differently in specific situations. (RBR50 vs. RBR750, for example.)
Is it correct to assume that when Block Sites is changed to "Never", that web browsers are able to open that web site?
- diz420Jun 14, 2024Aspirant
No, because even with set to Never and a list that is empty, I still cannot access the sites that were previously on my list. I make sure to click Apply and I have rebooted all of my devices, routers and modems....negative.
