sd2421
Aug 30, 2020Aspirant
Cannot update firmware on Netgear Orbi BRK753S-100NAS
Firmware version V3.2.15.25
Cannot update firmware to V3.2.16.6
Auto download fails for router (not satellites) with 'update failed' message.
Manual download works, but a manual update also fails.
How am I to update?
Please post about this over in the Orbi AX forum.
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Use a different browser, IE11, Firefox, Edge or Opera.
Be sure the downloaded .zip file is unpacked.
Good Luck.
Good Luck.
- sd2421Aspirant
Was able to update after unpacking the zip
I would recommend that the error message be updated to provide this information to make it easier for users to utilize self-help in diagnosing the problem.
Thanks for your help...
Glad you got it working.
https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-router-using-orbilogin-comEnjoy. :smileywink:
Any progress on this?
sd2421 wrote:Netgear Orbi BRK753S-100NAS
How am I to update?
