5598JC
Sep 15, 2022Aspirant
Canot login to Router
Hi Please Please can someone help Im sorry to sound stupid and im sure this might have been covered So I call support who send me a Link to be able to login to my Orbi. The link does not work...
Sep 15, 2022Guru - Experienced User
So if you disconnect the RBR from the ISP modem and leave 1 wired PC connected to the router and press the reset button for 15 seconds then release. Clear all browser caches, then after the front LED starts to pulsate WHITE, enter 192.168.1.1 in to the web browser and walk thru the setup wizard, using the manual setup option, can you get to the home screen?
5598JC
Hello
Thank you so much for taking the time to help me much appreciated thank you so much
- FURRYe38Sep 15, 2022Guru - Experienced User
Let us know if you can get in...
- 5598JCSep 15, 2022AspirantThank you
Yes I got in there
Basicly I have a 02 Boost box which connects , so my mobile phone signal is boosted
As I could not see it in Connected devices , I wondered if I acidentially blocked it from connecting
It still won’t connect so I’ll call 02 for a replacement
I managed to see the security settings and clearly nothings blocked
Thank you- FURRYe38Sep 15, 2022Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
