VicVinegar
Jun 26, 2021Tutor
Can't access management through app or web
I just set up a RBK753 system a few days ago. Now I can't access the management app or management through a browser. I tried orbilogin and 192.168.1.1 . Internet access is working fine. I am not ...
borkbrok
Jun 26, 2021Tutor
I'm also experiencing the same thing on my RBR/RBS753 series from Costco.
I'm running V3.2.18.1_1.4.14 on all three devices. Armor is off and all my satellites are the recommended distance away from each other.
If I reboot the whole system, I'll be able to access the web portal for a few minutes, but then it just fails to respond after that.
- FURRYe38Jun 26, 2021Guru - Experienced User
Try a factory reset on the RBR. Press the reset button for 15 seconds then release. Setup from scratch with a PC and web browser.
I would setup the RBR with it disconnected from the ISP modem. Then after setup is complete, connect the RBR to the ISP modem.
borkbrok wrote:I'm also experiencing the same thing on my RBR/RBS753 series from Costco.
If I reboot the whole system, I'll be able to access the web portal for a few minutes, but then it just fails to respond after that.- borkbrokJun 26, 2021Tutor
I've already factory reset 3x without connecting to the ONT first this week. I'm using a Frontier FIOS 1 gig router
If the modem already has a router built in, this would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
borkbrok wrote:I've already factory reset 3x without connecting to the ONT first this week. I'm using a Frontier FIOS 1 gig router
