Justbenice
Jun 20, 2021Aspirant
Can't add more than 2 satellite to RBR750 in AP mode and satellite not sync with rbr750
Hello. I just bought a system with 1 RBR750 and 4 RBS750 . When i setup this systems, if i using router mode in RBR750 then the system work very fine with the whole four satellite and one router, ...
Justbenice
Hi,
My network setup like this :
ISP moderm -> Draytek Vigor 2926
-> Netgear Prosafe Switch 24 port (unmanaged and cheapest one) -> Rbr750 at AP dynamic IP .
I connect 3 of the satellite to the switch by wired and one near the RBR750 with wireless.
I can see all those satellite in RBR750 admin page but it doesn't sync.
And i don't know why the satellite3 is do wireless backhaul instead of wire backhaul .
Sorry for my bad English
Jun 20, 2021Guru - Experienced User
To get this working right you need to connect the RBS to the back of the RBR, not in parallel:
- JustbeniceJun 20, 2021AspirantThank you!
I'v read that topic few times already, but the problem is this network setup were working good with my old Netgear RBK23. And after i upgrade to RBK754 and it did not work any more.
And this kind of network setup also work if i set my RBR750 as Router. It only stop working when i change the RBR750 to AP.- FURRYe38Jun 20, 2021Guru - Experienced User
For router or AP mode, RBS still need to be connected bahind the RBR, no in parallel.
- JustbeniceJun 20, 2021AspirantWhat a bad idea for this kind of expensive mesh system.
