Dertastic's avatar
Dertastic
Cant add Satellite to existing setup
Hello, im using Netgear Orbi WiFi 6 Mesh System AX4200 (RBK753) with 1 router and 2 satellites. works fine. now i wanted to expand the wifi to my basement and wanted to add Netgear Orbi AC2200 to my ...
  • plemans's avatar
    May 24, 2022
    The AC satellites aren't compatible with the AX systems.
