dbrb2
Jan 10, 2022Apprentice
Can't add setellites to RBR750 in AP mode
I have an RBR750 router, running V4.6.5.14_2.0.54, with 2 satellites, all of which arrived from Amazon today. Because, when acting as a router, the RBK750 has rather limited firewall and DNS cap...
Jan 10, 2022Guru - Experienced User
What is the brand and model # of your host router or DHCP server?
You might wanna update FW and see:
dbrb2
The router is openWRT
Some progress is being made:
Amazon have agreed to replace the hardware with a copy that has not already been registered with Netgear, giving me the opportunity to raise tickets
In addition, by leaving the satellites connected to the master via cat5 for some time, they have now synced.
Router:
RBS750
V4.6.5.14
No Internet
Satellite
RBS750
V4.6.3.16
Orbi Satellite-1
However, the firmware page shows the above - perhaps the version discontinuity was a problem. The reported status seems odd - they are difinitely on the imternet, since I am using them to post this message! I am guessing this is a bug to do with being in AP mode...
A manual firmware update with the relevant files for the satellite:
https://kb.netgear.com/000064226/RBR750-RBS750-Firmware-Version-4-6-5-14
failed with "Firmware upgrade failed. Please check your file." As part of this, it tried to open the web interface of the satellite - http://192.168.1.31/fwUpdate.htm - however this hangs. Each satellite was listening on port 80, but seems to return an empty page when I query it with wget
After a factory reset of both satellites, they seem to have responded and taken the firmware uodate....
