niels1292921
Feb 18, 2023Aspirant
Can't change Chromecast to 2.4 GHZ on Orbi RBR350
Hi all, I want to adjust my chromecast device to 2.4 ghz instead of 5. But it seems there is no option in the Orbi app. Can anyone help me out? Casting is a lot of patience atm... thanks!
Feb 18, 2023Guru - Experienced User
The orbi's can't split the 2.4ghz/5ghz.
But why would you want to connect to the 2.4ghz? Its a much much slower network and sensitive to interference. 5ghz is significantly faster. Especially if you're using a chromecast for streaming.
