niels1292921
Feb 18, 2023Aspirant
Can't change Chromecast to 2.4 GHZ on Orbi RBR350
Hi all, I want to adjust my chromecast device to 2.4 ghz instead of 5. But it seems there is no option in the Orbi app. Can anyone help me out? Casting is a lot of patience atm... thanks!
CrimpOn
Feb 18, 2023Guru - Experienced User
It might help to describe what has prompted this request.
With Orbi routers, it is the device that chooses which WiFi channel is best. Chromecast supports both 2.4G and 5G WiFi.
