niels1292921
Feb 18, 2023Aspirant
Can't change Chromecast to 2.4 GHZ on Orbi RBR350
Hi all, I want to adjust my chromecast device to 2.4 ghz instead of 5. But it seems there is no option in the Orbi app. Can anyone help me out? Casting is a lot of patience atm... thanks!
Mikey94025
Feb 19, 2023Hero
It sounds like you have Chromecast wireless connection quality issues while using 5Ghz and believe that 2.4Ghz, with its greater range. If your Chromecast is selecting 5Ghz then the signal strength is good enough to perform. We can help optimize your Orbi wireless performance so that your Chromecast streams better. Do you have other devices that struggle over your Orbi wireless? Have you tried changing the 5Ghz channel using orbilogin.com?
