michaeljritchie
Jul 21, 2021Aspirant
Can't change IP address for my RBR850..?
So my problem is that my Orbi RBR850 is only giving me speeds of 8/9mbps second, but I've come accross this solution to change my routers IP so that it does not conflict with my modem. However, when ...
michaeljritchie
Thanks for the quick reply, see mine below...
IP Pass thru on the ISP modem is not needed nor recommended if you have the Orbi RBR in AP mode. If your in AP mode then there is no firewall present if your using IP pass thru on the modem. You can change the Orbi to router mode then continue to use IP Pass thru.
Gotcha, thanks for this info. I've changed my Orbi router mode and kept my ISP modem in IP Pass thru.
Then you can also change the RBR IP addressing scheme as well.
So this is where I need help I think... Is there a recommended way to do the above and how is that done? Since putting the Orbi in router mode I can now get into the internet settings (see attached). I have not changed anythign there yet.
Thanks again.
Jul 21, 2021Guru - Experienced User
For that, WAN side that IP address comes from the ISP modem. You can change what the RBR gets from the ISP modem there. I'ts best to leave this section Dynamic...
Look at the Advanced Tab/Home and look at the Internet secion on the right side of this page, what IP address is listed here? You may see a ##.##.###.### listed here or maybe a 192, or 172 or a 10 IP address here.
- michaeljritchieJul 21, 2021Aspirant
Not sure I follow this... How do I change what the RBR gets from the ISP? Is that under the WAN setup tab? Or WAN prefence button?
Labeled screen shots attached to show where I'm looking.Look at the Advanced Tab/Home and look at the Internet secion on the right side of this page, what IP address is listed here? You may see a ##.##.###.### listed here or maybe a 192, or 172 or a 10 IP address here.
The IP address in the Internet Port section is a 192 one.
- FURRYe38Jul 21, 2021Guru - Experienced User
You can change that ON the ISP modems web page.
Are you looking to change the 192. address to something different on the WAN side or you wanting to change the IP address of the LAN side. These are different sections.
- antinodeJul 21, 2021Guru
> For that, WAN side that IP address comes from the ISP modem. [...]
No, it really doesn't. If your "the ISP modem" is acting as a simple
modem, then your router's WAN/Internet IP address comes _through_ the
modem, _from_ the ISP. You have no real control over the
external/public address which your ISP provides.In some cases, if you change the MAC address of your modem, or the
MAC address of the WAN/Internet interface of your router, then you
_might_ persude the ISP to grant a different address, but you can't
_force_ your ISP to do anything.
> It might be helpful to reveal some actual IP addresses of your
> various gizmos, so that we can better see how this stuff is configured.Still true.
