JWaldner
Oct 07, 2020Tutor
Can't Connect Epson WF-3520 to Orbi AX4200
We just bought and installed the Orbi AX4200 and so far it has been working ok with the exception of our printer. Our Epson WF-3520 printer can't connect even after resetting the wifi settings to de...
Oct 07, 2020Guru - Experienced User
Try setting the CTS value from 64 to 2347 and see if the printer will connect. Try with no wifi security temporarily on the RBR to see if the printer will connect to the open SSID. Then try WPA then WPA2. Do not select WPA3.
Be sure the printers FW is updated as well.
Contact the pritners mfr for additional help and information regardin there product as they will have more troubleshooting information.
If all else fails, use the LAN port on the printer to connect to the Orbi system.
- JWaldnerOct 07, 2020Tutor
Thanks for your suggestions but I have tried them all without any success. The firmware is up to date and relocating the printer so it's next to a satellite is not an option.
Any other recommendations?
Thank you
