JWaldner
Oct 07, 2020Tutor
Can't Connect Epson WF-3520 to Orbi AX4200
We just bought and installed the Orbi AX4200 and so far it has been working ok with the exception of our printer. Our Epson WF-3520 printer can't connect even after resetting the wifi settings to de...
Oct 08, 2020Guru - Experienced User
Contact the printer mfr for additinal help and information regarding there product.
Use the LAN port on the printer to connect to the Orbi system.
JWaldner
Oct 09, 2020Tutor
Epson was of no help other than to suggest buying a newwer printer, go figure. Moving the printer to a wired connection is not an option. Can anyone else help before I pay out more money for having a "better" wi-fi network? Thanks
- FURRYe38Oct 09, 2020Guru - Experienced User
Is the printer not in range of the RBR or RBS to connect it using the ethernet cable?
Do you happen to have your prior wifi router by chance?
