Florian_HSM
Apr 16, 2024Aspirant
Can't connect RBS 760 to RBR
I can't connect my RBS to the RBR after changing to AP mode; the RBS led stay purple and they don't appear on the "connected devices" page. Configuration: 1: Create orbi network 2: Connect RBS ...
schumaku
Apr 16, 2024Guru - Experienced User
Configuration:
2: Connect RBS to RBR (it worked)
3: Change RBR from router to AP mode
4: No more RBS (and i can't sync them)
Details: The 2 RBS have a continuous purple led and one of them appear on the device manager (with a 0.0.0.0 IP address and as a connected device, not a satelite)
When in AP mode, does the RBK use their own subnet or they need a proper IP address (the RBR is behind a firewall with manual IP, which made me think that the lack of DHCP if the issue here)
The Orbi system does depend on available IP communication, these are not "just" Ethernet switches, even in AP mode it's more than a pure Wireless<->LAN bridge - so without IP address it will be more than difficult, the sync can't work of course, too..
Florian_HSM
Apr 17, 2024Aspirant
I did a factory reset on my orbis and activated the DHCP on my firewall.
Now the satellites connect to the RBR and i see them on the orbilogon page; however the RBR keep rebooting itself every 2 to 3 min (only when in AP mode, the router mode doesn't have this issue).
- FURRYe38Apr 18, 2024Guru - Experienced User
Is the RBR set for Dynamic IP addresses or Static IP addressing while in AP mode?
If you disconnect the RBR from your firewall, does the RBR keep rebooting or stop?
- Florian_HSMApr 21, 2024Aspirant
When i disconnect my firewall (stormshield) from thr RBR, it stop auto-restarting.
The auto-restart happens no matter the RBR configuration (DHCP or Static IP, but only in AP mode)
- Florian_HSMApr 22, 2024Aspirant
After some testing, i found out that the RBR isn't really rebooting, it just deactivate and reactivate it's wifi (if i'm wired to the RBR, i can stay connect to the orbilogon page). I don't see any relevant informations in the RBR logs.
I tried to downgrade the RBR firmware to V6.3.6.4_1.2.68 but the issue is still here.
The only time when the RBR don't restart it's wifi every 1 to 3 min is when it is not connected to the firewall or when it is in Router mode.
