jimh394
May 07, 2022Star
Can't connect to my Orbi RBR750
Below is the message I get when on the desktop or laptop. On android phone I can see all 42 of my gadgets (printers/switches/cams, etc...), but I'm met with the message "We can't find your ORBI" and ...
- May 09, 2022
Yes, NG is aware of it.
Try the reset. Some users systems are working, just can't connect to the routers web page or use Orbi app. In these cases, users may need to give some time to NG to get this resolved. It's only Monday. Factory esets were mentioned as working in Reddits as well.
Forums are for user to user experiences and support. It's up to users to try what others have posted about. There's the Orbi app forum as well that has the more posts.Otherwise, users can contact NG support and ask for there help and information.
https://my.netgear.com/support/contact.aspx
May 09, 2022Guru - Experienced User
So you have your options, Try a reset, contact NG support or you'll need to wait for NG to fix this. Nothing else we can help with here in the forums.
jimh394
May 09, 2022Star
I hear you and agree. Will be doing a reset on Wednesday. Much appreciate everyone's feedback and advice. BTW, I will also be blocking auto firmware updates for the future as well as backing up my configuration once I get back to where I was. Love this community! Thanks again. Jim
- FURRYe38May 10, 2022Guru - Experienced User
Trying to help reproduce this no router web page log in problem. I reverted FW back to v.13 on my 750 last nite. Didn't factory reset. Just downgraded. Left it to see if it would update. I found this morning that it updated to v.2 around 1am this morning. I was able to log into the RBRs web page just fine. Even the debug page using MS Edge. Not sure what is happening with AU.
For anyone seeing this, I recommend you manually download FW and apply updates. Then factory reset and setup from scratch.
Seem to work better for some:
