roberthleeii
May 08, 2022Star
Cant connect to router but router is still working.
I can't connect to my router through 10.0.0.1 or the orbi app. The router appears to be working perfectly fine as regard to devices connecting to it for internet. I have done a couple of power cycles...
- May 09, 2022
I have the RBR753 and the reset worked.
It sounds like you cannot change anyting when you do the reset, skip the satellites and any customizations. I also used my desktop that was hardwired to the router to do the setup.
Jroach
May 08, 2022Luminary
I am also experiencing this symptom. Internet woks but can't access admin via URL or Orbi app on IOS. Power cycle, different browsers, nothing.
Were our orbi's hacked?
roberthleeii
May 08, 2022Star
If this is a net netgear issue I hope others chime in soon.
- JroachMay 08, 2022Luminary
I did see a tip to make certain that you are not on the GUEST network. I don't have GUEST setup so not the issue for me but thought I'd pass it along
