roberthleeii
May 08, 2022Star
Cant connect to router but router is still working.
I can't connect to my router through 10.0.0.1 or the orbi app. The router appears to be working perfectly fine as regard to devices connecting to it for internet. I have done a couple of power cycles...
- May 09, 2022
I have the RBR753 and the reset worked.
It sounds like you cannot change anyting when you do the reset, skip the satellites and any customizations. I also used my desktop that was hardwired to the router to do the setup.
Jroach
May 08, 2022Luminary
Robert, thanks for posting the steps!
Does anybody know if Orbi updates its firmware automatically?
roberthleeii
May 08, 2022Star
I think so. I am going to look through the settings and turn this off.
- JroachMay 08, 2022LuminaryRobert, good idea. I like having security updates on auto pilot but net gear is known for buggy firmware:(
