roberthleeii
May 08, 2022Star
Cant connect to router but router is still working.
I can't connect to my router through 10.0.0.1 or the orbi app. The router appears to be working perfectly fine as regard to devices connecting to it for internet. I have done a couple of power cycles...
- May 09, 2022
I have the RBR753 and the reset worked.
It sounds like you cannot change anyting when you do the reset, skip the satellites and any customizations. I also used my desktop that was hardwired to the router to do the setup.
dbnorton
May 08, 2022Tutor
This really sucks!! I would love to know how many others are having the same issue!! I would love to know how long I haven't been able to access my admin page of my router!! I am really not wanting to do a factory reset on my router but It looks like I may have too! I have a lot of static IP's that I will have to set back up!
roberthleeii
May 08, 2022Star
Dbnorton, I have several devices and applications dependent on static IPs. I had to go through and change all of my references for all the ips that changed and make static/reserved again.
I was surprised that a lot of my devices did come back back with the same IPs.
