roberthleeii
May 08, 2022Star
Cant connect to router but router is still working.
I can't connect to my router through 10.0.0.1 or the orbi app. The router appears to be working perfectly fine as regard to devices connecting to it for internet. I have done a couple of power cycles...
- May 09, 2022
I have the RBR753 and the reset worked.
It sounds like you cannot change anyting when you do the reset, skip the satellites and any customizations. I also used my desktop that was hardwired to the router to do the setup.
May 09, 2022Guru - Experienced User
What Orbi models do you all have?
NG is aware of users having problems with Orbi AX systems and orbi app having problems over this past weekend.
Any of your systems recently updated?
What version of FW if you get this information.
Some users have done a factory reset on the RBR and setup from scratch using a wired PC and web browser connecting with HTTP and 192.168.1.1 or orbilogin.com. If you do this, disconnect the RBR from the ISP modem/ONT temporarily to see if you can get the setup wizard started on the RBR in a web browser.
xxcasp3rxx
May 09, 2022Tutor
I was using the RBR850 AX6000 model.
Other then a firmware update that I manually checked for and ran 6 months ago I did not recently run any updates myself, and had no problems accessing the login page in those 6 months.
I can check the FW version it's currently running after the factory reset when I get home tonight but was unable to get into the router while it was locking me out to see.
As you stated I factory reset mine twice with no success, I had success on the third time around and I think I may have left the WAN connection unplugged at that point. Which is where I was finally able to reach the login page and run through the setup again.
- FURRYe38May 09, 2022Guru - Experienced User
Thanks for letting us know that worked for you.
As you stated I factory reset mine twice with no success, I had success on the third time around and I think I may have left the WAN connection unplugged at that point. Which is where I was finally able to reach the login page and run through the setup again.- roberthleeiiMay 09, 2022Star
Glad that worked. I agree that users should have to resort to this. Don't know what is causing it. All we can do is try the reset and setup from scratch.
Besure to save off a new backup config to file once your system is setup. I would do a back up to file before enabling any additional features like Armor, SPC or Traffic meter.
