roberthleeii
May 08, 2022Star
Cant connect to router but router is still working.
I can't connect to my router through 10.0.0.1 or the orbi app. The router appears to be working perfectly fine as regard to devices connecting to it for internet. I have done a couple of power cycles...
- May 09, 2022
I have the RBR753 and the reset worked.
It sounds like you cannot change anyting when you do the reset, skip the satellites and any customizations. I also used my desktop that was hardwired to the router to do the setup.
dtay
May 11, 2022Luminary
If I were to attempt the factory reset route, do I have to reset both the RBR and RBS or just the RBR only? My RBS are hard wired.
May 11, 2022Guru - Experienced User
Turn OFF the RBS. Just reset the RBR. 15 second press on the reset button then release. Walk thru the setup wizard with a wired PC or laptop and web browser at HTTP and 192.168.1.1.
