roberthleeii
May 08, 2022Star
Cant connect to router but router is still working.
I can't connect to my router through 10.0.0.1 or the orbi app. The router appears to be working perfectly fine as regard to devices connecting to it for internet. I have done a couple of power cycles...
- May 09, 2022
I have the RBR753 and the reset worked.
It sounds like you cannot change anyting when you do the reset, skip the satellites and any customizations. I also used my desktop that was hardwired to the router to do the setup.
May 11, 2022Guru - Experienced User
Turn OFF the RBS. Just reset the RBR. 15 second press on the reset button then release. Walk thru the setup wizard with a wired PC or laptop and web browser at HTTP and 192.168.1.1.
dtay wrote:
If I were to attempt the factory reset route, do I have to reset both the RBR and RBS or just the RBR only? My RBS are hard wired.
BrandX5
May 11, 2022Initiate
Does anyone know if this will be fixed by a firmware download, and we can wait this out?
