roberthleeii
May 08, 2022Star
Cant connect to router but router is still working.
I can't connect to my router through 10.0.0.1 or the orbi app. The router appears to be working perfectly fine as regard to devices connecting to it for internet. I have done a couple of power cycles...
- May 09, 2022
I have the RBR753 and the reset worked.
It sounds like you cannot change anyting when you do the reset, skip the satellites and any customizations. I also used my desktop that was hardwired to the router to do the setup.
dtay
May 12, 2022Luminary
So it's a given that Netgear is aware of the issues that their firmware has caused. But does anyone know for sure if Netgear is going to be releasing an updated firmware (and pushing it out automatically) to restore the network management access (via app and GUI) anytime soon? I'm sure their tech support lines are being hammered by calls.
May 12, 2022Guru - Experienced User
We don't. Others have posted that they contacted NG and is aware of it. No time frames.
