roberthleeii
May 08, 2022Star
Cant connect to router but router is still working.
I can't connect to my router through 10.0.0.1 or the orbi app. The router appears to be working perfectly fine as regard to devices connecting to it for internet. I have done a couple of power cycles...
- May 09, 2022
I have the RBR753 and the reset worked.
It sounds like you cannot change anyting when you do the reset, skip the satellites and any customizations. I also used my desktop that was hardwired to the router to do the setup.
mayecho
May 19, 2022Tutor
This seems to be a problem affecting thousands of users. A factory reset is the only solution working for people that must access the admin section. This is completely unacceptable and Netgear should be honest and open with what they are doing to fix this problem. I have several orbi's across the state and it would be very expensive for me to factory reset each one.
WE NEED A CLEAR STATUS UPDATE FROM NETGEAR.
Jun 15, 2022Guru - Experienced User
Any progress on this?
