Zooropean83
Sep 01, 2021Aspirant
Can't downgrade FW on RBR750
Hi I've been having some ongoing issues with my Orbi setup (RB753) which official Netgear support suggested I downgrade the FW to solve (the poblems began when 4.6.3.7 auti-installed). I have...
Sep 05, 2021Guru - Experienced User
ALL USERS of the 7 series Orbi AX system, please contact NG support by opening a support ticket and contact NG and ask them for the beta that seems to be avialable for the 7 series that seems to be directed to fixed what everyone with a 7 series has been having problems with:
https://www.netgear.com/support/#
For user out of warranty, contact Blanca_O and DarrenM and send them a PM and ask for the beta.
Good Luck.
Zooropean83
Sep 06, 2021Aspirant
Many thanks for your help, FURRYe38.
The link about using debug mode in Edge did indeed work - thank you for sharing it.
Downgrading the FW solved the issue but of course within an hour the router auto-updated the FW again. However support now tell me they have "elevated" the problem to a "higher tier". I imagine this means they will suggest I download the beta FW you have just mentioned.
Thanks again for your help.
- FURRYe38Sep 06, 2021Guru - Experienced User
You'll need this after you downgrade to v3:
IF you wanna try it.
Or wait for support to send you the beta...
- FodenDec 13, 2021Apprentice
Hi,
If you block 'devcom.up.netgear.com' and 'http.fw.updates1.netgear.com' - yes it really does need the 'http.' to be included - then the automatic firmware update will fail with "Service unavailable"
What was the trick to downgrade from v4 to v3 firmware? (found it)
Zooropean83 wrote:Many thanks for your help, FURRYe38.
Figured it out the hard way and then found the easy way - follow this https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/RBK750-Series-Firmware-Update-v4-6-3-7/m-p/2130584#M18586 (Post 77 and/or 78)
Am now on V3.2.18.1_1.4.14 on the router, going to downgrade the satellite now
Absolutley ridiculous process to go throught to try and get your router working the way its supposed to out of the box!
BTW NG the Traffic Meter seems to have been an issue with all your router series for about the last 10 years!
- FURRYe38Dec 13, 2021Guru - Experienced User
Be sure you block FW upates using a upstream router or the system will auto update back to v4.
