Zooropean83
Sep 01, 2021Aspirant
Can't downgrade FW on RBR750
Hi I've been having some ongoing issues with my Orbi setup (RB753) which official Netgear support suggested I downgrade the FW to solve (the poblems began when 4.6.3.7 auti-installed). I have...
Zooropean83
Sep 06, 2021Aspirant
Many thanks for your help, FURRYe38.
The link about using debug mode in Edge did indeed work - thank you for sharing it.
Downgrading the FW solved the issue but of course within an hour the router auto-updated the FW again. However support now tell me they have "elevated" the problem to a "higher tier". I imagine this means they will suggest I download the beta FW you have just mentioned.
Thanks again for your help.
Sep 06, 2021Guru - Experienced User
You'll need this after you downgrade to v3:
IF you wanna try it.
Or wait for support to send you the beta...
