niroooo
Sep 17, 2022Aspirant
Can't enable OpenVPN on Orbi RBK353
I am trying to enable OpenVPN on the Orbi RBK353 system. When I check the "Enable VPN service" box and click apply button I get: Dynamic DNS service is suggested to be used alone with the VPN Ser...
- Sep 17, 2022To have VPN service you have either to have a fixed (static) IP from your ISP or have a Dynamic DNS service. Otherwise how would your device know where your Orbi is when you’re outside your own LAN. 🙂
There are fee free DDNS services that you can participate in like NoIP or Netgear’s own DNS.
Only then you will be able to activate VPN on Orbi.
ekhalil
Sep 17, 2022Master
CrimpOn
Sep 17, 2022Guru - Experienced User
My older Orbi accepts only DDNS from three suppliers:
- Netgear
- No-ip
- Dyn.com
Each DDNS service has a proprietary procedure to update the DDNS when the public IP changes and Netgear has included code in the router that is compatible with those three services.
