niroooo
Sep 17, 2022Aspirant
Can't enable OpenVPN on Orbi RBK353
I am trying to enable OpenVPN on the Orbi RBK353 system. When I check the "Enable VPN service" box and click apply button I get: Dynamic DNS service is suggested to be used alone with the VPN Ser...
- Sep 17, 2022To have VPN service you have either to have a fixed (static) IP from your ISP or have a Dynamic DNS service. Otherwise how would your device know where your Orbi is when you’re outside your own LAN. 🙂
There are fee free DDNS services that you can participate in like NoIP or Netgear’s own DNS.
Only then you will be able to activate VPN on Orbi.
