laughingboyuk
Apr 02, 2021Aspirant
cant find option 61- Orbi 753 (AX4200)
I want to set this up with an vigor 130 modem but my ISP needs Option 61 to validate. Looking through the forums they said the orbi had this added in recent firmware updates. Ive put the latest f...
Apr 02, 2021Guru - Experienced User
I don't see it the UI. Something NG hasn't added at this point. I'd contact NG support and give them your information. Otherwise, use the ISP Modem for it's option 61.
- laughingboyukApr 02, 2021AspirantThanks. Frustrating as it seems some other orbi models do have it.
I want to use the orbi as a router and the modem as a pure modem so I dont have a double nas.- FURRYe38Apr 02, 2021Guru - Experienced User
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopTry option #2 then...
- laughingboyukApr 02, 2021AspirantThank you. This is a particular issue in the UK with one of the biggest ISPs called sky. Their service needs option 61 to authenticate so without it, it wont work.
I have the system working with their own modem/router with the orbi on top of that in AP mode, but I lose some of the orbi functions doing that and have trouble with my NAS.
The ISP modem/router doesn’t have a modem only mode to allow the orbi to sit as a router on it but I bought another modem which is setup and hoped to use the orbi as a router with that.
The Sky ISP forums have post from people with orbi’s working with option61 activated in the firmware but it doesn’t seem to exist in the rbi753, at least so far.
