quang777
May 07, 2022Guide
Can't find Orbi RBR750 after factory reset
Long story short, I was having issues with our wifi connectivity and was trying to access the web interface to make some changes. However, this morning I could no longer access the router's admin web...
MB_Love
May 07, 2022Apprentice
You can’t find the router after factory reset? Most of us stopped working after bad firmware was pushed. As far as I know factory reset is only fix. So you are saying after factory reset you still can’t connect to router?
- MB_LoveMay 07, 2022ApprenticeDid you reset to factory settings or just reboot?
- quang777May 07, 2022Guide
I first did a factory reset of the router and tried both the QR scan as well as "manual" set up and in both cases, the Orbi app couldn't find the router. I did have my modem connected at the time to the Orbi router. After that didn't work, I also factory reset the satellites too without luck.
Sounds like I might have to try this tftp method to get an updated firmware?
https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client
Thanks,
Q
- plemansMay 08, 2022Guru - Experienced User
Try setting it up by hardwiring a pc/laptop into the router and NOT using the app.
The app's had issues lately from what we've seen reported.
But you should still be able to set it up with a pc/laptop
