kemcfarling
Jan 31, 2024Aspirant
Can't find printer on WiFi
HP OfficeJet 8740 All-in-One Printer Netgear RBKE963B Orbi 960 Series Quad-Band WiFi 6E Mesh System Apple iMAC Ventura 13.6.4 Recently upgraded from Netgear Nighhawk. Since the upgrade, I can't...
- Feb 01, 2024
Thank you - will give it a try!
Feb 01, 2024Guru - Experienced User
No it should still work fine. Or mine does and its from the same manufacturer.
One thing to try is to go into the orbi and resevere the IP address for the printer.
I've seen some printers go on/off the network and it get new IP addresses. This can cause the need to reinstall the printer (if its on a different IP address). Reserving the IP address can fix that if that's the issue.
kemcfarling
Feb 01, 2024Aspirant
