macbates
Oct 16, 2020Aspirant
'Can't find server' errors with ORBI 753
I’m having some Internet issues with a newly installed Orbi RBK753 system, and haven’t been able to figure out how to solve them. What happens is that I will quite often get a “Safari can’t connect t...
Coney129
May 18, 2021Aspirant
Solved! So I had the same issue with a new WiFi 6 Orbi RB850 system. I called tech a bunch to try and figure out , downgrading software etc. Turns out it was modem. I had an Orbi RB40 that worked fine prior, but the modem couldn’t handle the new WiFi 6 system. Got the Netgear CM1000 and bingo, solved the problem.
