Adesa's avatar
Adesa
Follower
Dec 28, 2020
Can't get high wifi speeds on mbps on iPhone Pro 11 on my Orbi RBK752 system
Hi all
I have recently just installed my Orbi RBK752 system and have a stable connection in my home in every corner. On my laptop I can reach wireless speeds around 500 Mbps, but it seems like my iPhone Pro 11 can't reach above 200 mbps even when I am next to the router? Shouldn't I be able to reach higher speeds, when the iPhone is wifi 6 compatible? Can it be something in the wifi setup that I should change?
