Hondamaker
Mar 17, 2021Aspirant
Can't get more than 22Mbps anymore
I ususally get 100 or so Mbps download but recently I've only been getting 20 or so. Nothing has changed here AFAIK. I've rebooted both the modem and the Orbi several times, I've moved the Orbi out i...
Hondamaker
Mar 27, 2021Aspirant
And no, I haven't done a factory reset after last update. If all else fails I may try that if you think it might help.
Mar 27, 2021Guru - Experienced User
Please give feeback to the other questions as well. Might be helpful.
- HondamakerMar 28, 2021Aspirant
A factory reset did the trick. It was very quick and painless, not what I expected. Thanks for your input.
- FURRYe38Mar 28, 2021Guru - Experienced User
Be sure to make a backup configuration to file for safe keeping. Saves time if a reset is needed.
Be sure to mark your thread as solved so others will know.
Enjoy. :smileywink:
How do I make a back up of my configuration?
