adzify106
Mar 04, 2024Guide
Can't get Pixel 8 Pro to work with Orbi
150m2 house with an Orbi RBK853 no other devices having issues. Did a quick search and apparently there are issues with Pixel phones working on Mesh networks. I can connect to the network but it is...
Mar 04, 2024Guru - Experienced User
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
Something to ask the phone Mfr about.
- adzify106Mar 04, 2024Guide
I don't know if you saw the update but I've found a workaround, so the clue to resolving the issue is something about the shared SSID and how the mesh network interacts with the phone.
- Firmware for the phone is Android 14 running March 5th Feature Release.
- Firmware for the RBR850 is V7.2.6.21_5.0.20
- No, wireless only.
- Channel Configurations are currently:
Region Australia / New Zealand 2.4 GHz Channel Auto (2) 2.4 GHz Wireless mode: Up to 1147 Mbps 5 GHz Channel 36 + 40(P) + 44 + 48 5 GHz Wireless mode: Up to 2402 Mbps - FURRYe38Mar 05, 2024Guru - Experienced User
What's the work around?
- adzify106Mar 05, 2024Guide
In Router Wireless Settings I enabled the IoT Network and set it to 5GHz only. I connected the phone to that network and it fixed the speed and connectivity instantly. So the issue is with the main AX shared SSID network, I'm guessing for some reason the way Orbi broadcasts the network it is confusing the device.
The phone is not the problem as it's WIFI clearly works so there must be an issue with the main network. As I said in my first post apparently Fast Roaming and Band Steering appears to cause this but I can't see any options to disable in the Orbi firmware.
