rpras
May 14, 2022Initiate
Can't get to 192.168.1.1 from any browser.
This same issue started on my RBR750 - I noticed this today. Can't get to 192.168.1.1 from any browser. The Orbi app does not find the router. Some of the ethernet clients are also not connecting to ...
- May 30, 2022
Just to update: last night, this issue was fixed. I did not do anything - must have been an update from Netgear. The firmware version is V4.6.8.2_2.1.9. Of course, the first thing I did was to back up my settings to a file so in case any such event occurs in future, I'll have my settings backed up. That said, I'd like to see a setting in the router to periodically backup the settings to a file.
Thanks Netgear!
May 15, 2022Guru - Experienced User
rpras
May 30, 2022Initiate
Thanks Netgear!
- FURRYe38May 30, 2022Guru - Experienced User
Glad it's working again. Please mark your thread as solved so others will know. Keep the configuration file on hand. Saves time if a reset is needed.
Enjoy. 📡
