pumpface
Jun 17, 2025Aspirant
Can't Login with Admin Credentials
 Can somebody please help me? I'm trying to set up my Orbi RBR350 and I've followed all the prompts in the app until I've arrived at the screen asking me to Login with my admin credentials. It asks me...
- Jun 24, 2025
Thanks - I had factory reset it in the past and the issue existed, this time after a factory reset it prompted me to enter my own custom password which I did and setup has gone okay from here.
CrimpOn
Jun 24, 2025Guru - Experienced User
pumpface wrote:(there is no option for me to select no smartphone)
Can you post a screen capture of this page? I do not have a 350, but the other Orbi routers I have configured sort of bury the option to use a web connection to configure the router. (Tiny type, sort of fading into the background.)
