pumpface
Jun 16, 2025Aspirant
Can't Login with Admin Credentials
Can somebody please help me? I'm trying to set up my Orbi RBR350 and I've followed all the prompts in the app until I've arrived at the screen asking me to Login with my admin credentials. It asks me...
- Jun 23, 2025
Thanks - I had factory reset it in the past and the issue existed, this time after a factory reset it prompted me to enter my own custom password which I did and setup has gone okay from here.
pumpface
Jun 23, 2025Aspirant
Hi CrimpOn
Thanks for getting back to me. The Orbi is not new, purchased in 2023 so I have no support available other than this blog (which I find absolutely ridiculous).
I am still stuck at the third step, when clicking the orbilogin link, it provides me with two options:
- Download the app (there is no option for me to select no smartphone)
- Shop for wifi and mesh routers (not relevant)
Neither of these options give me any ability to login. I do get the ability to login via the app - however the default credentials do not work. I have tried to put 'password' in a million times and it just fails every time. Its as if I need to find a 'forgot my password' option so I can reset it, however this option is totally eluding me.
Following the additional instructions also do not lead me to where I need togo. This link http://192.168.1.1 asks me for login credentials which I donot have and this link http://10.0.0.1 does not connect.
Why do they make this so hard?
CrimpOn
Jun 23, 2025Guru - Experienced User
pumpface wrote:http://192.168.1.1 asks me for login credentials which I do not have
When a Factory Reset is performed, the login credentials are "admin" and "password". Guaranteed. Have done it many times.
If those credentials are not accepted, then the Factory Reset did not happen.
- pumpfaceJun 23, 2025Aspirant
- CrimpOnJun 23, 2025Guru - Experienced User
It might be useful to review this Netgear document:
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
i.e. simply pressing the "Reset" button is not enough. Reset has to be held for a considerable amount of time. 7-15 seconds.
Glad you are "back in business"
