yanivf
Nov 28, 2022Apprentice
Can't see attached devices - RBRE950
I added some static IPs and rebooted my router. After that clicking on attached devices open a page with empty table with no devices. The main menu shows proper count of satellites and devices. Inter...
Nov 29, 2022Guru - Experienced User
If you delete one of the static devices and then reboot the router, do they show up?
yanivf
Nov 29, 2022Apprentice
Thank you plemans for the quick response. I was about to do what you suggested and checked again and now all my devices showing up. Not sure why it took 24hrs. Maybe the list is getting pulled from Netgear servers and they had an issue but don't see a reason why they would store it at their cloud.
