yanivf
Nov 28, 2022Apprentice
Can't see attached devices - RBRE950
I added some static IPs and rebooted my router. After that clicking on attached devices open a page with empty table with no devices. The main menu shows proper count of satellites and devices. Inter...
iyang
Nov 30, 2022NETGEAR Expert
Hi yanivf ,
What's model do you use ?
I added some static IPs => do you mean that you set reservation ip for your devices ?
Thanks.
- yanivfNov 30, 2022Apprentice
Hi iyang , yes the reservation able in the DHCP section. I had some devices before and everything worked but just added few more and after the reboot the issue happened. Netgear has some bug for sure in showing devices but if adding the static ips to table is the cause isn't clear.
To your question about the model - I have orbi 950 (the router is rbre950)On the positive, it's started to work again by itself.
- Mikey94025Nov 30, 2022Hero
My RBKE963 system running V6.3.7.5 also started showing nothing in Attached Devices. I have 89 devices - Do you have a large number too?
If I use the browser debugger I can see that pushing the Refresh button makes an AJAX query to "http://orbilogin.com/ajax/get_attached_devices?id=xxx". This call is successful and does returns the list of devices in JSON. The AJAX call takes a long time: 12 or 13 sec for my Orbi network. This long time may be why nothing appears on the HTML page.
I wonder if there is a timeout somewhere that is prevent the result from being rendered. The JS code is http://orbilogin.com/jquery.js and the AJAX call is made on line 141. I can't tell what the timeout value is being set to.
Very interesting Mikey94025. I'll explore the script. I have around the 50 devices. Try to see if you see your list by going to access control.
