Orbidude
Dec 29, 2021Guide
Can't send pictures to a digital frame with the RBR850 and 2 satellites
I purchased 2 identical digital frames which only work at 2.4 Ghz. I'm using the RBR850 router with 2 satelites. I couldn't send any pictures to the frames no matter what I tried. My brother took one...
michaelkenward
Dec 29, 2021Guru - Experienced User
Orbidude wrote:
How do I separate 2.4 and 5 Ghz on the RBR850 so that I can choose 2.4 Ghz on the digital frame?
You can't separate the 2.4 and 5 GHz. And there is nothing to choose on the digital frame. If it can't connect to 5GHz, it will connect to 2.4 GHz.
How do you set up these unnamed digital frames? (I assume that you have contacted the people who made these devices.)
If you have to use a mobile phone, one way to set up an IoT device is to disable the 5 GHz connection on the phone. That will force it to connect to 2.4 GHz. When the frame is up and running you can restore the phone's 5GHz connectivity.
Orbidude
Dec 29, 2021Guide
Hi Michael,
I noticed that you can't separate the 2.4 and 5 GHz. The frame see's ORBI as my connection.
The set up was pretty easy and I did contact the seller. They are looking into this as well.
How would I disable 5G on the iPhone Pro 13 for instance?
Thanks!
