Orbidude
Dec 29, 2021Guide
Can't send pictures to a digital frame with the RBR850 and 2 satellites
I purchased 2 identical digital frames which only work at 2.4 Ghz. I'm using the RBR850 router with 2 satelites. I couldn't send any pictures to the frames no matter what I tried. My brother took one...
CrimpOn
Dec 29, 2021Guru - Experienced User
Would really help to know the specific brand and model of digital frame.
And michaelkenward is correct. Orbi models have no method to assign different SSID's to 2.4G and 5G. (The "latest and greatest" model does feature a seprate 2.4G SSID just for Internet of Things (IoT) devices, but it costs $1,500 - wow!)
Orbidude
Dec 29, 2021Guide
CrimpOn wrote:Would really help to know the specific brand and model of digital frame.
Hi CrimpOn,
Here's the link to the digital frame.
https://www.amazon.com/dp/B099DJB4CF?psc=1&ref=ppx_yo2_dt_b_product_details
I just spent $1,000 6 months ago for the RBR850/2 satelites. Not ready to spend another $1,500. They are crazy expensive.
Thanks
- CrimpOnDec 29, 2021Guru - Experienced User
Orbidude wrote:
Here's the link to the digital frame.https://www.amazon.com/dp/B099DJB4CF?psc=1&ref=ppx_yo2_dt_b_product_details
Oh, my. Unusual to see a product with 30% 1-star reviews. (and only 23 reviews total).
I have yet to find a User Manual for the product.
- OrbidudeDec 29, 2021Guide
I think I may have figured it out. I have 2 routers in the house. The Orbi is on the second floor and the tp link in my recording studio, where I had the frame. As soon as I connected the frame outside the studio and in my living room, everything started working. I guess the frame was having difficulty connecting to a router even though it showed it was connected to the Orbi.
If you're wondering why I have 2 routers, one is for the internet and the other for my ethernet/ Dante equipment.
Thanks!
Cool. Problem solved. No need to create separate SSID's.
