Orbidude
Dec 29, 2021Guide
Can't send pictures to a digital frame with the RBR850 and 2 satellites
I purchased 2 identical digital frames which only work at 2.4 Ghz. I'm using the RBR850 router with 2 satelites. I couldn't send any pictures to the frames no matter what I tried. My brother took one...
Orbidude
Dec 29, 2021Guide
Hi Michael,
I noticed that you can't separate the 2.4 and 5 GHz. The frame see's ORBI as my connection.
The set up was pretty easy and I did contact the seller. They are looking into this as well.
How would I disable 5G on the iPhone Pro 13 for instance?
Thanks!
michaelkenward
Dec 29, 2021Guru - Experienced User
You would be surprised how many useless IoT installation programs there are out there. Too many have yet to discover Mesh wifi networks and their single SSID.
No idea. I am too cheap to buy iThings. I would have thought that Apple would be a better place to ask about that. Or set the things up with a mobile device that is easier to use.
